Configure a VNID
Use the following procedure to configure a VNID, which identifies one of the potential 16 million VXLAN segments that can coexist within the same administrative domain.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select VTEP.
  3. Select the Vnid tab.
  4. In Identifier, assign a unique value to this VNID.
  5. In Isid, specify the I-SID associated with this VNID.
  6. In Action, select one of the available actions: none or flush.
  7. Select Apply.
Vnid Field Descriptions
Use the data in the following table to use the Vnid tab.
Name
Description
Identifier
Specifies a value that uniquely identifies the VNID of this VXLAN tunnel end point.
Isid
Specifies a value that uniquely identifies the I-SID associated with this VXLAN tunnel end point.
Note:
A VNID must not have the same value as an I-SID.
Action
Choose one of the following actions to take with the MAC FDB:
  • none: Don‘t take any action. This is the default.
  • flushMacFdb: Flush all the learned MAC addresses from the forwarding database of the selected VNID.
OvsdbConfigured
Specifies if the VNID is configured with OVSDB protocol support for VXLAN Gateway.
